captainryder
I bought some motorcycle flags for special rides. ( Like the USO Run in Missouri to Ft. Leonard Wood - June 13th)
Its a double flag mount. Provided is a metal bracket about 13" long and 1.5" tall that has mount holes on both ends for flag holders. The bracket is to be installed behind your license plate with both ends extending out from the plate.
http://www.tagflags.com/
Above link shows the dual flag set-up. (SEE PRODUCTS - "BANDIT" ITEM
Question: Any ideas if this bracket is enough to stiffen the license plate holder on the fender to do this? I'm thinking another plate of metal on underside of fender will be needed. So from top to bottom, the license bolt will be through the plate, the tagflag bracket, the plastic fender, then finally another metal plate under the fender.....?
Comments: :chat:
Comments: :chat:
