Mirrors on 2011 RS SE5
jimsturges
I searched topics and didn't locate an answer.......
My problem is with handlebar risers my grips and hands are right in the way of the factory mounted mirrors.
Are there any bar mounted mirrors available like on a Harley or may other bikes that will mount on the Spyder? Generic mounts would not work due to the different design of the Spyder handle bars.
Anyone else run into this problem? And is there a fix.
Thanks in advance
Jim
Thanks in advance
Jim
i believe what you need are up n out extensions by tricled or custom dynamics
Mirror Extensions Best investment I made
I had the same problem with my 2012 RS SE5. Almost caused an accident on the highway once. I got the extensions and could not be happier! The best money I ever spent on the Spyder!
Jim
I just ordered a set from Black Widow Supply for 129.00 it was the best price I saw. I appreciate you pointing me in the right direction. ImageUploadedByTapatalk1437414367.314192.jpgImageUploadedByTapatalk1437414427.991481.jpg
If anyone else is interested the first picture shows the mounts.
The second picture of the yellow Spyder shows one side factory and the other side with the extension on it.
Jim
Spyder_Jim it looks like I jumped too soon. I could of saved some $$ by ordering from Value Accessories thanks for your response !
Jim
Here you go..!!
attachment.php
the only thing is the wiring. You either remove the plugs (mine had instructions on how to do that) or cut and splice. The turnsignal wires run through the upper arm. The other thing is the half covers are really tight (Nelson Riggs) when extensions are installed. But they work great...:thumbup:
I just ordered a set from Black Widow Supply for 129.00 it was the best price I saw. I appreciate you pointing me in the right direction. View attachment 111883View attachment 111884
Jim
i would throw a caution up to purchases from black widow. There are bad reports on here regarding them.
http://www.spyderlovers.com/forums/...essories-Order-problems&highlight=Black+widow
Well knock on wood..... Guess I may have gotten lucky or they have cleaned up their act..... Called them this morning and the order had already gone out !!
Jim
