Mirror
Emilio Velez
Hey guys Have a question. My right side mirror on my 2015 ST Limited, Shake a lot, here's a photo of the mirror and it seems to be opening up at the seam. Has anybody had this problem and what can I do? No Magnets for ST's Thank You.
Certainly looks like the mirror casing is coming apart! Have you tried removing the mirror & seeing if the covering sections are all fixed properly? :dontknow:
Bottom piece looks like it is in place. The top looks like it is being "pushed" up. Make sure the wiring harness is sitting inside properly. It is a tight fit, but if it isn't laying down correctly, it may be be contributing to the misfit.
:agree: when I replaced mine with the chrome accents there was not much there to lock in place:lecturef_smilie: careful when removing as the springs clips brake all too easily. I believe there were 2 little screws barely accessible behind the mirrors(not 100% sure) will look if I still have the info somewhere. *note did not have to remove mirrors to install, just the wind deflectors* & with yours separated it can get water & dust in around the led blinkers , ya you need to seal & or fix sooner.
Found the info:yes: FYI you need to remove the lower 1/2 first; this gives access to the screw holding top 1/2 on. 39FB8CAF-002F-4B41-BA6C-A0F2AC304DD4.jpg6782AA52-102E-4BBC-B7EA-51E9FE79BC33.jpg
A84C15D3-EBBF-4FB9-85C9-8BE7890C7E4D.jpg it has a note on pic 3 * “make sure she’ll is well inserted into support screw” P1 is the shell 1 is the support screw: looks like where you’d came off. Hope this helps:2thumbs:
The Mirrors on the ST are different then the one's on the RT's Clips on RT are on the mirror mount on the ST on the Bike.IMG_20190529_151727.jpgThat' s the new clip I replaced the old one.
