mirror glass replacement
spyderfriendly
Yeah I broke one. Got a 2010 Spyder RT. Broke a mirror. Anyone know where to get replacement glass that will allow use of the led lighted arrows without buying the whole unit?
Well, been there and done that! I stuck a blind spot mirror on mine (the right side) and didn't like the position of it and tried to take it off, you guessed it, the mirror broke as I was pulling on the little spot mirror. A day before my vacation heading out for a cross country trip. I went to Advance auto, bought a plastic mirror that you can cut with good sissors. made a little templet with paper and stuck it on the cracked mirror. then I reinstalled the blind spot mirror in the right position. Well, that was a year ago and it is still there, not quite as clear as a glass mirror but it is o.k. a new one from the dealer is north of 140.00 dollars. My plan is to dissassemble it and see if I can get a mirror cut for it at a glass shop for 10 or 20 bucks and put it back together. For now the plastic one is fine. I will be heading for spyderfest in April plastic mirror and all, after all, it has already been across country with me and I'll take it on at least one more trip. :ohyea:you can see it in my picture below with the little blind spot mirror on it. it works fine and most people don't even notice it.
Glass shop..!!
Most glass shops can cut to size. Mounting should not be a problem but I'm not sure about the arrow business..good luck... :thumbup:
