Micro switch on SM5 located where the clutch/wires are
burg650
Anyone know what this micro switch is for on a 2010 SM5, as I said it is located between the clutch cable and wires just zip tied there.
Clutch switch. I believe it won't let you start the engine in gear unless the clutch is disengaged. As far as I know, it also triggers the clutch assist solenoid. For the RT, it also kicks out the cruise when the clutch is pulled in.
