End of 2019 I did it, got my F3S tuned with MaptunerX. In total you have 4 different options so I started with the first level which you can use with normal 95 octane petrol. Results were quite nice although unfortunately actual numbers are missing ( this is the only negative for me). Now here in Europe they have moved to E10 ( higher level of Ethanol) and the advice of the dealer was to use 98 octane petrol in order to avoid higher levels of ethanol in the spyder. Found that a good reason to adjust the tuning of my F3S ( mind you changing the tuning is completely free for each installation, no limits ). The highest level requires 104 octane petrol which I do not want since there is limited availability of the petrol. Decide for level 3 which in reality is level 2 + ATC. The Agressive Throttle Control is really making a difference in all gears. I have not been able to test topspeed since I need to go to Germany for that but the torque and throttle response are very good.
Installing or Changing levels is a breeze, just go in the workshop and it is done. Nothing to remove, it is executed via the ecu connector.
Price may seem high but with the Try & Buy offer you have little to loose.
So for those who were still in doubt, perhaps my story can help you to decide.
For any Dutch readers, I had it done by MotorCompany in Nieuwerkerk a/d IJssel ( Martijn Minnee), excellent service overthere:clap:
