Map on Signature
How do I add the map that I see so many have on their posts, that show a map of the U.S. with supposedly states that they have traveled through?
You should be in "Forum Actions", then Edit Profile. At the left are buttons to change avitar and signature. Note the size limitations. Hit save when done. Refresh your browser to verify.
Map Signature
I can't figure out how you get two maps to show, I have the providences map and the US, when I try to add the second one it changes off the first one and only displays one, they were done in the small size and as a jpeg?
Let's see if this worked. Resized profile pic, and already re-did map. Nope profile pic still not showing. Resized it down to 300x271 at 40.8kb, and upper limit is 98kb, so don't know why that isn't still working
You need to set your avitar pic, not profile pic to have it show up on your posts.
And if you want 2 maps to show in your sig, you need to combine them into a single .jpg
Your profile pic IS there. I just looked.
Please re-read what I posted above. What you're trying to do is have your AVITAR pic show up at the top left of your posts. It's a seperate pic, NOT the "profile pic".
:agree: Avatar and Profile pictures do not have to be the same. Each one is configured separately. :thumbup:
Map Signature
I found one that can display 2 maps side by side creating one pic, some of you have a map and pic side by side, cannot figure out how you got both linked to appear?
