Major question
MOSESS
I own a 15 special series RT. . my question is does the F3 limited have more rear seat room then the Rt. I have been so busy with work ,I have had no time to check on this so thank you and please keep in mind that I am 6ft 6inches tall and I want more leg room. I know the F3 has the Rt beat for the driver.
I'm unsure what you are saying or asking.
A show room test sit is probably going to be your best answer. F3 does offer a few aftermarket seat options though. It sounds like it is going to be a bit of an adventure.
AK has it spot on, Mosess. At 6’6” you need to sit on the F3 set in position 5, with your passenger behind you. It’s the only way you will know the fit. I still needed my seat moved back 1.5”, but Russell managed to give the rear seat the same amount of room.
Pete
