Maintenance Do's, Do Not's, Tips and How To
seaweed
Many times using the search function will help a person that wants to Do some maintenance but there is not a good way to search for Maintenance Do Not. Also for Tips it is possible (sometimes) to find some assistance with the search function. I would like to start this tread (that perhaps someday could become a sticky) to assist in finding the Maintenance Do's, Do Not's,Tips and How To's.
But some times the hint is buried in a thread with many posts. If a thread has many post to it there is a short cut for the user to find the post in question. For example instead of stating
Post #14 http://www.spyderlovers.com/forums/...nt-Problem-amp-Question&p=1099971#post1099971
the person submitting the tip could go to the above link then left click on the #14 in the upper right hand of the original post and a new URL is shown in your address bar. Use this new URL shown below and the use is then taken directly to post in question.
http://www.spyderlovers.com/forums/...amp-Question&p=1099879&viewfull=1#post1099879
An example of Do's would be one from billybovine to make sure that the reservoir caps are put on correctly after adding brake fluid.
An Example of Hint's would be like one from Lamononster for clearing hyper-flash turn signal.
An example of Do Not would be do not mix different types of coolant fluid (color?)
http://www.spyderlovers.com/forums/showthread.php?59676-2014s-Go-To-Orange-Long-Life-Coolant&highlight=mixing+coolant/
A thread, post or video may be a Do and a How To, or any combination. Please add to the list for all of us beginners. Thank You:)
Maintenance Do and How To
How to inspect your Spyder's brake pads.
Very good video thanks to Finless Bob
New 2014 Spyder ST Limited. Just rolled over 4000 miles. Oil change at 600 - next change?
msbabe
I do not have an answer to your question. But having that said, I was hoping that this tread could be used by spyderlovers to post MAINTENANCE DO'S, DO NOT'S, TIPS, AND HINTS.
So if spyderlovers out there have some please post them here!
:rolleyes:
Beginning on pg 105 of msbabe's ST Operator's Guide is the complete maintenance maintenance for the vehicle which, inter alia, calls for oil and filter changees at 4,600 mile intervals.
Maintenance Hint: Give the Operator's Guide a scrutinizing squint.
