Lrndthehardway
Any ideas why when I pull the main relay I can get my 2011 RTS to run perfect after the P1614 code until I shut it off? Heres the story up til now. Cleaned the TB, put relay back in and started it up, it ran perfect, shut it off and put airbox back on and started it up to make sure it was still good and it ran like crap again, no throttle, high idle etc. Took airbox back off and started it, same thing. Pulled the main relay again, reinserted it and it started right up and ran perfect, until I shut it off again. All panels and frunk is off so got codes 2228, 0113 and still had the 1614, assuming the first 2 are because sensors are disconnected.
Checked all electrical connections, checked small map hoses, and checked bat voltage already. TB was replaced once already in 2014, and bike has just over 16k miles.
Any ideas?
Any ideas?
