LOWER BELLY PANS ON RT
Chazzman
I just installed the SPYDERPOPS block off plate and converter shields. It says to remove the lower floor pan to allow for proper cooling. I removed the right side pan 2, 10mm bolts going into the frame and 1 on top. Should I also remove the lower pan under the left side as well?
I think some leave off the left side to make oil changes easier and faster. One less thing to remove. You do not need to remove it for the shields or the block off.
