low voltige questions
vt228
my spyder is showing me the Low Voliage across the screen and then the battery light gos on off when shutoff well not start till i charge battery what is causing this to happen no neion lights on turned them off pulled fuse's to them still low voltiage on screen anyone know why ????
And if the connections under the tupperware (not under the seat) are tight and without corrosion then you just may have a bad battery.
Though if you can trickle charge it and it stays charged (at the same voltage) for a couple of days sitting in the garage then the problem may be in the Spyders charging system.
Don, if you find corrosion on the terminals, clean them to shinny and tighten them. Then what I have used in the years living in Louisiana, is an ample application of grease on the terminals, applied AFTER the tightening has been done. If the battery has been drained because of corrosion, you may need to charge it, then hopefully you're good to go.
MY BATTARY WAS DEAD TERMNELS WHERE LOSE HAD NTO PUT NEW BATTERY AND VOLTAGE RELAY IT WAS FRYED RUNS BETTER THEY HAVE A NEW FIX FOR THE SPYDER AND UP DATE SO THEY RUN BETTER AND NO BACK FIREING MORE TORK ...
