Looking for a good water proof phone case
HIspyder
For an iPhone 7 Plus.
Looking for a good case which is not only water proof but also anti-glare.
Thanks in advance!
The Iphone 7 is already water resistant. I rode in the rain and no issues. I wouldnt go swimming with it though.
When starts raining I put in my pocket. If it's raining too hard (only happened once) I also put it in a sandwich baggy. Blue tooth still works.
Thanks in advance!
Otterbox.com
I have had one for my phones and gps. You can use the phone or device when it is in the box and throw it in the water and it will not damage the device
Don't get a ram-mount aqua box Pro 20.
Clear screen started coming away from rubber from day one. Never was totally waterproof. Ended up keeping my phone within a sandwich bag within it. Also no way to charge phone while it was in it.
ZIP
ZIP-LOK bag....
very effective, cheap, durable and if you loose it, go back to your kitchen and get another.... :firstplace:
i keep 2 in my tank bag, 1 for the phone, the other for the GPS... then i keep in Xtra in thr frunk.... :yes:
Dan P
SPYD3R
PS; and you still have 'touch screen' abilities....
But Dan,
I wouldn't suggest trying to use the bag that you had your peanut butter and jelly sandwich in... :shocked:
It would be too tough to read the screen! :roflblack:
iPhone water proof case
I use a zip lock bag, right over the top of the phone and the mount Put a rubber band around it to hold the bag in place Total cost, $0.20
:clap:
Fireproof Case
I currently use a fireproof phone case for my Galaxy S7. The biggest drawback is the charge port cover is hard to open and headphone port require a single
(Included with case).
Otter box is the way to go. I'm am plumber and while working on a Comercial sewer pump, my phone fell out of my pocket into the 6inches of black liquid. I pulled it out rinsed it in fresh water. Never had a problem with the phone.
I've tried many, many different cases for my iPhones.... and flat out the LifeProof was the best. Currently use it with my iPhone 6+. Works great. The Techmount works fantastic for mounting to handlebars.
Do you still need to remove gloves to use the iPhone once the lifeproof is on, Firefly?
Pete
