Looking for a answer for a starting problem with my 2014 RTLimited
For the first time I have seen this problem with the spyder which has 34,000 miles on it.
When trying to start the bike, a picture of a key pops on the screen and it says KEY DET and the bike will not start. Bike is in N and the brake is on, turn it off and on again, same problem. Shop time, could not find any code to that problem and re-keyed the keys. Worked for one day, same problem. If I try it a number of times it will clear and I can start the bike. Does anyone know what the problem might be. Ron:banghead:
thanks for the responses I will have them check that issue. And this just started when I installed the CAT pipe from Lamont so I hope that's not a problem cause I like the sound with my Two brothers pipe.
Sounds like the DESS is on its way out:yikes::lecturef_smilie: other reports have been straight FAIL no warnings. Hope the dealer can save you from being stranded. Keep an eye on it & spare keys handy.
The DESS modular will need to be replaced. If yours has not been changed in the past then yours is 4 or 5 mods behind.
Good luck!
Have the DESS system turned off and forget about it. The only person it prevents from starting the bike is you.
Wish I were closer, would be happy to give you a hand with this.
OK, Yes I'm a newby here, but what is the "DESS"?
Search on DESS and you'll see enough threads and posts it'll hurt your brain! It's a well known problem with the early 2014s. Usually requires the DESS module, ignition module, and keys to be changed.
Just a quick question for future reference...... If the DESS starts to go bad, can it be relatively easily "turned off" without getting into a big expense? It this just a BUDS tweek?
