Look inside the rear fender
Pogo
Hi guys.
I had the rear fender struts replaced on my Spyder a couple of months back. The dealer made a meal of the job, using the wrong nuts, which led me to remove the rear fender to check for damage.
Inside, I found that the fender support was badly cracked. I've put some pics in my album here. If these go much further, the fender will fail. :shocked:
It should be possible to check for this by just removing the fender. Next time you have a maintenance day, lift the rear fender and have a look.
Cheers;
Pogo
Very interesting pictures to say the least. Do those cracks go all the way through the piece of metal? I just had my rear fender off the other day, installing my new TricPlate, and I didn't see any damage like that at all. Is there a chance someone hit your Spyder in the rear or something without you knowing about it? :dontknow:
Hmmm :popcorn:
Yes, SpyderWolf, they are full depth. It is possible that they were caused by the fender supports not being properly fitted, but I thought it worth warning others. It would be disastrous if the fender hit the wheel at speed.
I just had my rear fender off the other day, installing my new TricPlate, and I didn't see any damage like that at all. Is there a chance some one hit your Spyder in the rear or something without you knowing about it? :dontknow:
There is no damage at all on the outside of the fender (other than the paint rubs caused by the butt-ugly reversing light bracket that was fitted to our models).
Anyway, if you've looked and seen no damage, you can ride on happily. :thumbup:
I'd be interested to know if anyone else has cracking like this.
Cheers;
Pogo.
Mine cracked like that two only worse. I thought it was from the other fender brackets cracking which let alot of vibration happen which the stressed this bracket. I beefed up those brackets over the winter and no problems so far.
