Long distance highway tire pressures?
troop
Well-known member
Ok ... The F3S is all loaded up and ready for a trip that will involve 1700 freeway miles, with speed limits of 65-80 mph. Particulars are:
Vredestein fronts currently at 16psi
Cooper Ultra CS rear currently at 18psi
The bike will include loaded up Shad side bags, Pack Rack-56L top case and frunk. My geared up weight is 225# and no passenger. Wondering if I should bump up the psi a pound/two per tire to compensate for the higher speeds/load? I will be sandwiching the freeway portion with about 500 miles worth of "scenic" riding. Just wondering about a happy medium. Thoughts?
I think you are fine. As the tires heat up they will gain a few PSI anyway. Our trip to Nova Scotia involved two up and loaded for bear. 16 in the Federal fronts and 18 in the Altimax rear for that trip. All was well.
Those tires and the PSI's are fine just the way they are ..... ( and I'm a Tire guy :roflblack: ) ..... enjoy .... Mike :thumbup:
I would not change a thing. When touring the only time I fiddled with TP was when I went to higher altitudes for extended periods of time (a week or more). Constantly being above 5000 feet (Utah, Colorado) I would deflate 1-2 lbs. Then when coming down in elevation I would add the air back in. I didn't do this daily. Only when there was a big change in elevation for long periods of time. Have a great trip..... Jim
The dealer set my Vredsteins at 15 lbs. and the Kumho at 28 lbs., "Tire guy" thoughts :cheers:
28psi in the rear I found was too high and a cause of oversteering/understeering (I can's remember which). My book of truth says 28 psi, but my opinion/experience says that figure is for 2 up loaded ryding/touring. My 2020F3L is now set for 16-17 fronts and 22-23 rear. Rear may still be a little high. My tyre wear has been over 20k km rear, not quite down to the wear markers. Almost 30k km fronts being changes for a long tour coming up, but not down to the depth markers yet. Kendas of course. Keep smiling and don't wory too much because these are technically well above average bikes that are very forgiving.
The Vredesteins are two lbs. less than I use, because I drive very aggressive in the twistie's , but 15 is fine .... it will improve the comfort feel of that tire .... But the Kumho at 28 is 10lbs more than my Pirelli at 18lbs psi .... and this will cause two things very Bad wet road handling and very un-forgiving ride ..... jhmo ... ( and probably Peter's also ) ...... Mike :thumbup:
Sorry but I dis-agree with everything you said ..... jmho .... Mike :thumbup:
