Locked
Theseminole
I have a 2009 RS Spyder. This morning when I went to go take a ride my handlebars were stuck in the locked position. I tried to juggle the bars an turn the key. I pulled to both side while turning the key. Any help would be awesome. Thanks
turn the handlebars all the way to one side (i cant remember if it is left or right) and then turn your key to unlock the bars.
hope this helps
Cruzr Joe
All of the above
you need to be a bit forceful pushing it the dirction you locked the bars. So if bars in left turn push left firmly..if right then right. If this does not work the lock may be broken.:gaah:but just to be sure...you are not pushing down on the key like opening the seat or frunk...??
Locked bars
As others have said, push the bars all the way left or right depending which way they were locked. Hold the key loosely, don't push down, wiggle it around left/right, move the handlebars a little, try key again etc. and hopefully it will unlock sooner or later. It is a "feature" to keep anyone from stealing the bike. Mine is fussy whenever I get them locked too. Good luck
i think i locked my bars once years ago when you had rings on the side and you had to put a lock through them. and that was the only time. i have insurance, so if they want it, take it.
