limp mode again
quasi
cruising along at 65mph, cruise control set. coming into a construction zone, went to slow to 55mph and bang, LIMP MODE AGAIN! was like I had laid on the brakes. car behind us near ran into me. VSS, check DPS, check engine e.t.c. this thing has went into limp mode on me twice this year. I don't care what anyone says, that is a good way to get someone killed and the idiot engineer who designed the system needs a beat down. my battery connections are all good. charges at 13.9 volts according to the gauge. next time I ride this bike will be to trade it in.
Did you check for the active xodes?
first time it happened was about 6 weeks ago or so. got hit with a hard crosswind. no codes that time either.
That certainly is unusual. Limp Mode is invoked when something goes wrong and the error code is placed on the bus.
Given what happened you might check your brake fluid level.
checked the brake fluid. added 3 cap fulls to the rear reservoir.
The codes are stored in the ECU, but you will need BUDS to retrieve them. Would strongly suggest you get this looked at rather than ignoring it.
Trust me, there are codes in your cars that if set will drastically reduce power if they set as well. This is SOP on all modern computer controlled vehicles to protect the hardware and safety.
Yes, I understand its frustrating but you need to get it fixed, not ignore it and hope it goes away like you did the first time it happened.
This is scary stuff happening, very uncomfortable feeling.
I expect you are correct. I would take it in if there were a competent shop in the area. there's not so I won't. i'd be ahead to just go ahead and buy buds with a one yr license and check it myself. the first time the bike went into limp mode the crosswind put me off on the berm so the vehicle lost traction and i'm sure the left side of the front end came up a little bit. yesterday, I tapped the brake at 65 mph to kick off of cruise control and the bike went into limp mode.
Scary stuff
This is scary and unsafe to say the least.
I know that many people have put many trouble free miles on their spyders. Unfortunately I'm not one of the and neither are you.
I got rid of our 2011 Spyder RT SE5 due to mechanical issues and just bought a 2014 RT SE6 in a private sale.
Here is a link to my wonderful journey which is really really disheartening. I can't even trade mine in on anything until it's fixed. Once it's fixed, I'm not sure how confident I'll be on it.
http://www.spyderlovers.com/forums/...sappointing-maiden-voyage-on-new-to-us-Spyder
The best of luck with yours
I know mine turns off the Cruise control when a deep pothole makes the wheel come off the ground. Then the bike slows way down fast.
Your brake fluid was low as you stated. that is way it went in to limp mode when your speed dropped.
Your rear brake pads might need to be replaced.
Any chance that you had your foot inadvertently resting on the brake? This will definitely cause the bike to kick into limp mode.
When was the last time your Spyder was put on BUDS? It was my understanding that Limp Mode was changed (reprogrammed) on 11 and newer models so that it no longer slammed on the brakes. It will limit you to 5000 rpm but you can maintain speed by upshifting at low rpm.
