Limp home mode
CK53
New member, first post. Just received passenger backrest, install was a snap, and the heated grips. Not the hardest thing I've done just a little time consuming but now I have the dreaded limp home mode scrolling across the console!!! Before I tear it down again and check the all the connections hopefully someone has an idea what it might be. Thanks in advance!
Thanks Johnny!
Code P060 D. Throttle accelerater sensor!!!
There's been some talk on the BRP tech board about some throttle sticking with stock grips and heated grips. Make sure the throttle returns all the way.
Ooops..!!
throttle "fly by wire" are very sensative. If the throttle snaps back fully then check the wiring to the sesor ans servo. make sure you always remove the key and walk away with it so the computer can reset. It may have picked up the problem before you were done...:thumbup:
Still there! Last thing I want to do is "limp" to the dealer to get this "easy installation" fixed! Double crap!!!
