effgjamis
Ride Forrest Ride!
for the past two weeks, after the replacement of the new throttle body I still get LIMP and check engine .. However, no error code is displayed.
CPS is aware and a throttle body position sensor is on its way From BRP.
Today:
Not sure.. but again today at a stop light, level ground it went into limp mode and then check engine.
An interesting thing.. Got home, used the kill switch to turn off the motor, and while I was on the phone, it went into Limp mode and Check engine, with me just sitting on the bike.. Yes, the ignition key was still on as I had not turned it off after using the kill switch to shut the motor down...
OH Well time will tell.
Today:
