License plate light replacement.
MrBones
I need a new lens only. All the parts catalogs only show the whole set up. Does anyone know if and where I can buy the lens only?
2015 F3-S. Thanks for any help. Also tried e-bay but not good at finding stuff there.
Agree...
:agree: they also have one that replaces the reflector with a lens so it will also be a running light. Put a bit of silicone on the edges to make sure it does not fall off... :thumbup:
I could send you the clear part from my broken Custom Dynamics set up. I'm pretty sure it will fit. It has a little stain from some glue, but should do the trick. PM me if you want.
Sent from my XT1585 using Tapatalk
DANG
Went to both places and could not find it :banghead: Went through all 5 pages on C.D. On Amazon couldn't get anywhere. Not too smart I guess. Can you direct me a little closer?
I think I found it on Amazon. but it says will fit my 2010. Does it fit both? I hope! And is that black frame part of it as I need it also?
Just be careful about mounting the new assembly, as the plastic is thin. You should use a washer and silicone. Look up the past posts on this and learn from our mistakes!
