Lamonster
SpyderLovers Founder
Seems this is something a lot of folks have been looking for and it's fairly cheap and easy to do. I'll give you a parts list and you can do this mod too. :doorag:
First off you need to order some parts. This is where I got mine, the price was right and I received them in a timely manner.
I used this ball mount to mount to the air wing.
http://www.gpscity.com/ram-mount-plastic-flange-base-with-b-ball-rpr.html
I tapped the ball with a M6 tap so I could use the stock torx bolt but the ball has a hole through the center so you could just run a 1/4" bolt through it. You will need to line up the flange of the ball mount to the top of the air wing. Then you want to make your hole so you can drill your hole. You can do this without taking anything off, just make sure you hold the wing when you're drilling it so it won't bend too much.
Mark your hole for drilling
Tap if you like
I used the short arm and this cup holder.
http://www.gpscity.com/ram-mount-self-leveling-cup-holder-no-foam-ram-b-132b-wh1u.html
here's another option for the cup holder
http://www.gpscity.com/ram-mount-self-leveling-cup-holder-foam-ram-b-132bu.html
Here's the arm I used
http://www.gpscity.com/ram-mount-short-arm-b-socket-ram-b-201u-a.html
When you put the arm on it will rest on the dash and that takes any weight off of the air wing. So far it's working out great for me and if you do the other side with the ball mount it makes a great camera mount. :doorag:
Tap if you like
