Lamonster RT Ultra Bright LED Fog Lights
Lamonster
SpyderLovers Founder
We just finished testing our Lamonster LED fog light replacement bulbs for the Spyder RT.
These are a clean white light to match our LED headlights. On the 2014 on you can change them out without tools and without removing any body panels. Just reach up and pop the cap off and twist the bulb out, unplug and pop the new LED bulb in. These run cooler than the stock bulb and draw less power.
These are Lamonster branded and come with a 2 year replacement warrantee. The price for the set is $42.95 and that includes free shipping in the USA.
You can order here http://www.lamonstergarage.com/lamonster-rt-ultra-bright-led-fog-lights/
Lamonster LED headlights, LED foglight on the left of pic and stock yellow teeth bulb on the right of pic.
Well, if these are anywhere near as awesome as your LED headlights and the LED DRL kit I just purchased and installed on my F3-S, sales should be SMOKIN'! :bowdown:
@lamonster is there a LED replacement for the ST fog light?
Sent from my VK810 4G using Tapatalk
Will they work on an ST? I just ordered your LED headlight kit for my ST. The fog lights that I installed from BRP are not very bright.
fog lights
Same easy install on 2015 RTL? Haven't installed LED headlights yet but on the list this week. Thanks.
Done
And done. Very bright. Rightside is easy peasy------Left side not so much. Glad i switched over.
Kaos
Lamonster's LED headlights are on my shopping list. I'll probably go for the fog lights as well. Very nice product Lamont!
Pam
Can you please tell how you replaced the hard side left fog light bulb which is out on my 2014 the thanks
I'm going to be doing that shortly myself. Since I need to change the spark plugs per the maintenance schedule, and that is easiest done by taking off the frunk, I'll be changing the fogs to LEDs at the same time!
Hi Rudy,
The left side is harder, no doubt. After removing the plastic tupperware I had to move ( not remove ) the air intake tube to access the headlight. Strong hands help and you can't have hands that fit in 16oz boxing gloves. But it is doable.
Lew L
