Lamonster Comes Through(again)
Bootie
I was in Maggie Valley when I noticed my ISCI handbrake wasn't releasing after braking. It being Sunday I couldn't go to a dealer for help. I did not have my tools with me. I gave Lamont a call and he said I could use his garage and tools to ferret out the cause. Some of you may remember that Lamont's is about 70 miles from Maggie Valley.
To make a long story short, it took several hours to find that the SLAVE CYLINDER was FUBARed. I told Lamont what I found and he said "YOU KNOW I HAPPEN TO HAVE A SPARE ONE OF THOSE". I couldn't believe it. How many people (in the world) would happen to have a spare ISCI slave cylinder on hand? I installed it and it worked just fine. Problem solved!:thumbup:
I can't thank Lamont enough and I thank my lucky stars that he had a spare on hand.:2thumbs:
Same thing happened to another Spyder Ryder when riding the Alcan Hwy. Caused Spyder to keep going into limp mode.
Bootie, glad it worked out for you. your a luck man these days, you called my wife to bring you oil in northern KY today., but i heard you called back and the police were there to help. you sure get around! its nice having people! Spyderlover people are everywhere. call anytime Brucenojoke
Luck ran out
:yikes:I was almost to Cinci when I got Zero Oil Pressure reading on my newly installed oil pressure Gage. I finally put some more oil in and started it up.:(OIL OIL EVERYWHERE. Spyder is in the shop now. Don't know what the problem is. I suspect that my new oil pressure system has blown. I hope I didn't ruin the engine.
I was going to ask you about that gauge when I saw the sending unit. Did the fitting crack or something?
Warning-oil pressure Gage.
OK, I'm back on the road again.:thumbup: Problem was that the Oil Pressure Sending unit hangs off of the T-Fitting. Engine vibrations caused the fitting to crack and break off.:yikes: the sending unit is pretty heavy and with the engine vibrations it's pretty hard on the T-fitting.
For those of us that want to continue to use an oil pressure Gage, we need to either anchor the sending unit so it doesn't vibrate or find a stronger T, or both. :lecturef_smilie:
Spyders to the Rescue
Thanks for all your offers of help:thumbup:It looks liked more oil would not have helped. It's good to know you are there, though.
Can you find a flex hose to fit? That way you could mount the sender remotely.
Oil pressure
Putting a hose on it would work but remember the oil is around 75psi and is hot. I don't know if we'd be asking for more trouble. That's why we opted for the electrical sending unit in the first place. Oh well, live and learn.
True. I was thinking more along the line of having a hydraulic hose made up...possibly with a braided stainless outer. It comes down to which is riskier...both carry a possibility of failure.
