Kuryakyn Brake pad covers
StarTraveler649
bought the brake pad covers and the handle bar chrome accents from Kuryakyn. Ordered on thur arrived today. the chrome really dresses up the empty slots on the handlebars.
Problem I am having is I cannot get the brake pad covers to fit. I double checked on their site to make sure I ordered the right ones, I did, checked to make sure they sent the right ones, they did. They specifically state for the '08 - '09 Can Am Spyder.
Instructions state they fit over the stock rubber pad, if the screws were 2-3 times as long, maybe, but would have a huge, nasty gap there.
Am I missing something ? Tried both sides, moved them all around, etc., etc.
Any hints ??
They look great, just can't put those babies on !!
I just looked at their website and it appears that those brake pedal pad covers should be really simple to install. I got this from their installation instructions...
Procedure
STEP 1 Separate the two halves of the brake pedal cover. Make sure the rubbers protrude evenly through the openings in the brake cover top.
STEP 2 Sandwich the stock brake pedal tread between the top and bottom halves.
STEP 3 Secure the top to the bottom with the 10–24 socket heads provided.
STEP 4 Any free play in the cover can be removed by tightening the set screws in the back half of the cover. Do not over tighten.
I have them on my bike you have to take the rubber pads off first for them to fit. The Kuryakyn pads fit nice and snug and look great.
BJT - did that, they don't fit over the existing pads, stock pads way too thick. Thanks though. They should be very easy to install,.
SixPAck - Is there any special way to take the stock pads off ? Looked at them last night and they are on there pretty good. Did not notice any mounting screws under there, but did not do a very good inspection.
