KRIKIT 11
bluep
Got one of these krikit tools. Question is what should the number be for proper tension on a 2014 RT-S ? I'm getting 180-200
KRITKIT II
On a 2014 RT......I have mine at about 185 ON THE GROUND ( and that makes a difference ) ...... I run my belt a BIT under spec. have NO vibrations, and No fear of damaging the engine shaft bearings ..................... Mike :thumbup:
If you are careful and do it correctly, you will get the exact same reading every time.
Well....
As seen here you are in the range. Losts of different readings and thoughts but as Mike :agree: stated loose is better than too tight. Different models and years have differnt spec's so you need to be careful with suggestions. If you check it after the dealer adjusts it (using that $800.00 sonic tester) you can see what your krikit reads and go from there....:thumbup:
bump
