Know of any 'slip-on' Seat Covers for RT's?
The seat on my 2012 RT SE5 is structurally sound, but the "pleather" has cracked, ripped and looks terrible. I have a lambskin cover that I put over the seat when I ride, but it can't be allowed to get wet. I can't afford a whole new seat (and don't need one...just the surface material). I have asked a local upholsterer about the cost of re-covering mine. His price was the same as buying a whole new seat! Does anyone know of any "slip on" type seat covers (rider seat and passenger back) for the RT? Just something to cover up the horrendous condition of the original material... I've thought about removing the seat, and trying to upholster it myself, but I have no upholstery experience, and the results would NOT be good! LOL
Another option if you like: B04C9A1A-6E9E-4231-9D77-DBE54F5F2505.jpegEE504262-91A6-4777-A012-87039EE502B5.jpegfound at Bass Pro, straps under seat with Velcro straps, quite adjustable & :thumbup:stays in place when seat is lifted
(when strapped right:p) leave it on 24/7 np in rain, does collect some dirt & grime between it & seat, simple to remove strap or two & wipe off with rag or towel, won’t really notice how much till you do clean there.(or if rains while at hotel & try drying seat in morning :popcorn:)
I looked for months as my 2012RTL like yours has gone bad. I didn't find any. I ran into the same problem as you the upholster wanted as much as a new seat. I finally went to Mark Hart at Hartco International and had him build me a new custom seat. He even builds a new seat pan you don't have to send him your seat. I know its you said you couldn't afford a new seat,but you are going to spend at least that much money anyway so get a really nice seat build to your specs. Talk to Mark.
Hartcoseats.com
You might check out BRP# 219400722; supposed to fit 2019 & prior RT's. A little pricey @ 112.19 (USD) and I have no idea if it will cover your lambskin, but worth taking a look at.
Another option if you like: View attachment 182723 View attachment 182724
View attachment 182725 found at Bass Pro, straps under seat with Velcro straps, quite adjustable & :thumbup:stays in place when seat is lifted
Sounds great! I'll check the Bass Pro Shop website. Thanks!
Hartcoseats.com
Thanks, but I just need a slip-on type cover. I have a lambskin cover that I use most of the time, but I
'd like something for all weather. :-)
https://alaskaleather.com/collections/sheepskin-buttpads/products/multistrada-sheepskin-buttpad
I have an Alaskaleather buttpad that I bought years ago for my Ducati 620 and 1100 air cooled Multistradas. Has served me well on two bikes, still works great, and was bought used from a fellow Ducati rider about ten years ago.
It just so happens that this sheepskin pad worked great on the drivers portion of the 2009 GS Spyder. It's really too big for the passenger seat on the GS/RS though.
And when I got the 2021 RTL last March, guess what?! This same "Multistrada" pad works equally well on either the front OR the pasenger seat of the RTL. Almost looks like it was made to fit! I am ready to buy another pair to have a matched set, front and rear, for the 2021 RTL. The only drawback is that two are needed but they work great for comfort for both rider and passenger while giving rider and passenger choices to use the pad or not, independently.
These quality sheepskin pads add comfort, probably add a half inch or so of ride height (good for a six foot tall rider) and are cooler in summer and warmer in cool weather. About the only time I don't use it is when it is cold enough to need the seat heater.
I have a lambskin cover that fits both rider and passenger areas, but not the vertical part of the passenger seat back. The lambskin is comfortable, and I like it very much. However, it isn't supposed to get wet, and my Spyder lives outdoors year-round. I put it on and take it off for every ride. It does a great job hiding the ripped and torn original seat cover, but I can't leave it on full time. :-)
I am sorry I did not more fully understand what you were looking for. I thought you wanted a slip on seat cover to hide your ripped original seat cover. If what you are looking for is a way to protect your sheepskin seat cover from the rain, Call Corbin as they make rain covers for their leather seats. The holes punched in the leather allow rain in to soak the foam. Hartcoseats.com also makes rain covers so maybe they can help you out.
You may be able to get a few names from a JoAnn's Fabric and Craft store, of people who do sewing in your area. If there are any "crafty" folks, they should be able to figure out a pattern and be able to do a 4-way stretch fabric cover that kinda resembles a tight, stretchy pillowcase. The cushioning and airflow from a sheepskin is wonderful but the getting wet part is not fun! Instead, you could put an "Egg Sitter" gel cushion on your seat, under the slip cover. The gel seat has a cover that could have elastic straps sewn to, to keep it in place, then slide the cover over it (or leave the cover off-one less layer to dry if it rains). The only issue you'd run into with a driver + passenger sized slip cover is that it can't slip all the way on to the back of the passenger seat because of the gasket support that holds the seat up. A slit and velcro from that point to the back would have to be put in there so it can go past that point. Anyway......you get the picture! Find a crafty stitcher and I think you could get something sewn for less than $100. Only thing is, the Egg Sitter seats are close to $40 each, so that brings the cost of comfort up again.
Most of the sheepskin seat cover providers sell rain covers that go over their sheepskin. Have a look at them. I’m sure they would be shaped to fit over both your sheepskin and/or the bare seat.
Pete
Years ago I had a rain cover for my seat. Only used it once. It was like putting Armor All on your seat.
Good suggestions... The padding under the leather is fine, no problems, so I don't need the egg carton stuff. My lambskin covers the seat completely (except for the passenger's back piece). It looks great and is very comfortable in summer and winter. But I have to put it on and take it off before and after every ride because I can't let it get wet. I might check with the Women's Group at my church. They do a lot of quilting and sewing. The cover doesn't have to be fancy...just something to hide the rips and tears in the original material. :-)
I still have TWO of the newer type RT seats and both would work on your 12, however Shipping would be VERY expensive. Un-fortunately you are too far away to deliver ..... Mike :thumbup:
