Kaoko Throttle Assist
twoseas
I'm having a problem with keeping the speed constant after tightening the friction ring.
The speed will creep up or down depending on which direction the throttle was adjusted.
Is anyone else experiencing this ? Is their a fix ?
Thanks.
Have one on my BMW GS, works great, have had it on the Spyder 2 weeks. I added Oxford Heated grips(a MUST) at the same time I installed the throttle lock, it does not seem to grip as solid as on the BMW but so far it works OK, I noticed I have to twist it a little bit more to keep it tight. Ride safely,
