Juicebox Pro Settings Help
larrymz3
Guys, I posted previously, but, never got a clear consensus on settings.
I have an 08 Spyder GS SE5 with the following mods:
1) K&N Air Filter
2) Hindle Exhaust
3) Juicebox Pro
What exactly should I set the Juicebox Pro to?
Thank you!
Larry
Start with map 2.You can change your trim settings from here if you like to add more or less fuel at low,mid or high range rpms by hooking up jb to computer while idling and see your changes.If you are like me you may need some reading glasses to see the numbers on the dials as they are tiny.Map 2 is for a single tb exhaust and map 3 is for a dual exhaust.If you look at the maps on your computer you can see the difference.
I am running map 3 because I have the Evo Race air filter(stock airbox removed).
Kman is correct .
I am hooking mine up today
1- stock exhaust and set up
2- single exhaust and k&n filter
3- dual exhaust and k&n filter
The two brothers website does not have any other maps for the spyder .
The juice box does accept power commander maps , which I haven't looked for yet , so maybe they have a better map , I don't know .
I can let you know what I find .
There should be a map section on the forum for guys that have been on the dyno with their spyders so they can share the map they have with their certain set up .
link to maps
ive looked for power commander maps -- they only have maps for two brothers and ron wood racin pipes-- i am guessing noone has never dyno tuned a yoshimura pipe on the spyder -- here is a link to the power commander maps for the RSS 2011
http://www.powercommander.com/power...ke=1&model=90&make-n=Bombardier&model-n=CanAm Spyder&year=2011&mk=1&mdl=90&yr=2011
the power commander only has 2 maps for th RTS 2011 and its for two brothers pipe -- heres the link
http://www.powercommander.com/power...ke=1&model=91&make-n=Bombardier&model-n=CanAm Spyder RT/RTS&year=2011&mk=1&mdl=91&yr=2011
here is the link to the two brother juice box pro maps
http://www.twobros.com/Perf_Products/Juice_Box_Pro/JuiceBox-Pro-Maps.htm
Are your sure that setting 2 is for the juicebox PRO not the regular juicebox?
Those setting are from the website and in instructions that came with my TB pro .
Maybe they take the same maps .
Mine seems to be fine on setting 2 - and I don't have the K&N filter in yet
My wife's 2008gs and my 2011rss both have Hindle with baffle removed. I have Kewl metal intake and she has k&n with modified air box. We both use powercommander map 5 (green filter and two brothers single exhaust. She gained 5-6 mpg over her previous settings. Throttle response is fantastic. Weaverage 33-34 mpg at 60mph. Go to Two Brothers web page then go to Powercommander page to down load map to install. I can't explain how but I did it and it works great.
