Seeing as I run pretty much the same setup, check my recent posts, you'll find a few informative ones.
In short:
-- I bought the Yoshi first. Had some popping/backfiring. Got worse over time.
-- I bought the Juicebox Pro. Went to install it, realized what a pain in the :cus: removing the airbox was, decided there was no way I was putting that airbox BACK in the bike, so then bought the Kewlmetal air filter system.
-- Using the included JB Pro settings I couldn't find joy. At a suggestion here I downloaded (via laptop plugged into the bike) the PCV maps for the Spyder (I now use Map 5 as my "baseline"-- this captures a single aftermarket exhaust and air filter).
-- Along the way, I also nuked my OEM O2 sensor. No certain reason why it went bad: could have been going bad already, running the Yoshi by itself for a month could have made it go bad, or messing around with all the JB settings could have made it go bad. Whatever the reason, I had to replace it.
-- Also along the way, I swapped out the OEM plugs with iridium plugs and new wires purchased via Spyderlover's own BajaRon.
So... after all that... how does the Spyder run?
I've had to tweak from the PCV Map #5 baseline, still haven't found the perfect sweet spot. The Map 5 setting for the high range is fine, the mid range setting is good but might be a little rich, the low range setting is probably too rich but if I set it all the way to the bottom (mggunner here on the board runs his that way) my bike will backfire after startup (usually at the first gear shift). Now that I've swapped out the O2 sensor and plugs, I went back to the bone stock Map 5, all dials set in the middle, and it seems to be running well enough.
However, I'm eager to find a dyno near me that can test out the Spyder. I plan on running my bike for a long time to come (especially now that the ST is out and didn't wow me into rushing out to trade my RS in), so investing in some good custom mapping is worthwhile for me.
That all said, if I had to do it all over again? I wouldn't. Yeah, that stock exhaust on the Spyder is a pig, but man, talk about pulling a sweater thread!
Bottom line: Get the PCV with autotune.
