JACK
SPYD3R
Hey SPYD3RLOVERS..... HARBOR FREIGHT has the 1500 lb. Capacity ATV/Motorcycle Lift
http://www.harborfreight.com/a-b-hp100912.html?utm_expid=14208462-11&utm_referrer=http%3A%2F%2Fwww.google.com%2Furl%3Fsa%3Dt%26rct%3Dj%26q%3Dharbor%2520freight%26source%3Dweb%26cd%3D1%26sqi%3D2%26ved%3D0CDAQFjAA%26url%3Dhttp%253A%252F%252Fwww.harborfreight.com%252F%26ei%3DFGYMUc6pKISW8gS7i4CoBg%26usg%3DAFQjCNGrimdtBnI6M-4JMZ1T3CN8GfHTFw%26bvm%3Dbv.41867550%2Cd.eWU
make sure you OPEN the link, and PRINT the COUPON... it'll be $79.99, without the coupon, it's $99.99, or even $149.99..... :lecturef_smilie: if there is not a HF in your area, you can call and order it, by using the coupon code number.....
:yes: GOOD LUCK guys n gals.... :thumbup:
jack points
I have a two-wheeler friend that has one of these and I need to replace the plugs, wires, and exhaust o-rings on my bike. Where, underneath the Spyder RS, is the best place to lift the front end?
I use it!
I use this jack...works great. Good value for the $'s. Inpsect the contents. I was lucky, had all the parts to assemble it. However, they were loose in the box and could have easily got lost....check your box to make sure it doesn't have holes or other ways for the parts to fall out....
Web Runner;
i go straight in at the front or side-ways at mid-ship... depending on what your needs are... at mid-ship, i can get all 3 wheels off the floor, but understand that when lifting like this, it is best not to get too comfortable under your SPYD3R, because it isn't the most stable and could fall over... when lifting the front, i ALWAYS put the emergency brake on, and a piece of 2 X 4 to lock the read wheel... whatever you do, do it safely.... :thumbup:
Just bought one at Sears its a Craftsman looks like the one Harbor Freight for the same price on line other than mines Red. Great jack for the money
I just picked up this exact jack at Harbor Frieght for $79.
Oil change this weekend and I will report how well it worked.
Bob
The HF jacks work good. With the yellow ones just don't be shy about stomping on the pedal fully to lower it slow and smooth.
Web Runner;
Thanks SPYD3R!
Is there any benefit to the aluminum jacks that run $175 at HF and Sears? Other than lighter weight and the opportunity to spend more money?
Nope... ;)
Now that the Missus has realized the weight of the new bike, and the rated capacity of my current lift, (only 1,000 lbs...); I think that I'll run this by her again...
She might authorize the expenditure! :thumbup: :pray:
Ordered aluminum one ( min hight 4.5 in to 19 in) steel was min hight 5.5 in . Used coupon code 28177679 , got it for $134.00
Searched harbor freight coupon on google and picked the best free one. I think you can use this one , try it ):
