ISO GRIPS
ttrac
Has anyone installed Kury ISO grips on a 2015 RT se6 limited without trimming the shifter paddle?
If you are using the ones that clam shell over the heated grips you are either going to grind down the shifter paddle or grind down the ISO Grip. I don't remember who it was now maybe finless but they decided to grind down the grip and were happy with that.
Thank You Pegasus1300 for your reply, that's seems to be the route I will follow, will grind some off the grip instead of the shifter paddle.
I watched your video finless, it is very easy to follow. As for the shifter I think it will require a little modification of the grip, as it looks now there won't be enough clearance to allow the shifter to move.
I ground down the lower clamshell instead of the shifter paddle. I used a dremmel and a bench grinder.
attachment.php
I took the half of the grip that was going to be mounted next to the paddle shift & marked with a sharpie what material to remove. Used a Dremel with a metal cut off wheel to remove material then fine tuned the cut as needed with a file. Just take your time & it will work great. You will not even notice the cut on the grip because of the bottom location.
