ISO Grips
2Gunns
RT-S PE#0032
I think I read a post staing that the ISO Grips "clam shell" would fit the RT but you would loose heat on the throttle side. Is that correct, and if so I'm confused. Could you explain why this would be?
The throttle side would be fine with a little work. The left side would be a problem for sure on a SE. You would have to make some notches in the grip so the paddle won't hit.
