Is there a way to make auxiliary plug work only while the key is on?
flash2002
Hi guy's, is there a way to make the auxiliary plug in the rear trunk work with the key and not always on. thanks.
Without looking for a circuit that is always hot, you could disconnect the existing connectors, and run new wires to either the battery or in my case, an added 12 volt aux. source.
So, you want to make the power go on and off with the key? Correct? If you have a 2013 or newer RT, look in your right side fuse box…,right side as you are sitting on it…. And move the fuse from the F7 position into the F6 position. Look at the fuse box page in your operators manual. Only one fuse is installed in F6. Leave the F7 position empty. If you have a 2012 or older, this option is not available.
Edit: looking at your past posts, it appears you have a 2011. So, no. There is no easy way unless you rewire somehow. It is always on.
Best, cheapest and easiest solution.
I've added a few extras to my 2011 RT and found a really neat spot under the left black cover under the frunk. Same place, but opposite side to where the BUDS connector is.
