Is the ST-Limited radio the same as the RT radio?
GrumpySteelMan
SpyderLovers,
Here's what I'm thinking. The RT has 4 speakers, two in the front, two in the back. The ST-Limited only has the front two. If the radio/amp are the same, then I've got some untapped stereo juice that could drive a couple of tweeters or bi-amp some high efficiency components.
I realize that there is a space limitation in the Spyder, but I want to do something with the stereo.
Are they the same? :pray:
If you can get your hands on a Catalogue, you could check the part numbers to see if they are the same
