Is it OK to run a Kenda KR20 rear with the original front Kendas?
Rdrnr
Gonna swap out rear in a few thousand miles with the KR20 that’s supposed to be better and last longer? Is it ok with the Kenda originals on the front? Pressure 26??
Are you R&R the rear tire yourself? If so, order a General Altimax 215/60R15 and have that mounted on. The Kanine won't last much longer than the OEM Kenda. Just my .02 :)
Yes I’ll do it myself. That’s a bit smaller tire? Now where is my bead breaker and spoons 🤔
Bit narrower and bit taller. It will bring your speedo to +-1 mph. Plus, it will last you at least 2X as long. You'll wrestle more with the bead/spoons on a car tire :) You run about 18# in rear car tire. I have the General on my RT S2S and really like it. New car tires will be mounted up front next Monday in replacement of some 3K mile front Kanines.
