Iphone-5 compatible with RT
SAPD911
I'm assuming I need the 30 pin to 9 pin connector? I have a bulky iPhone case, so I would need the $39 one with longer cable? And sticky tape to mount the phone in back?
Not sure what you are trying to accomplish ? If you are mounting phone in trunk , use a cheap case , put Velcro on back, put a Velcro strip in upper middle back of trunk. As far as cable , use existing cable for iPod connection, use the iPhone adapter to a smaller plug . I am assuming you have the factory audio system . This will give you control of music from phone, plus keeping it charged.
Good luck
You need to 30 pin to lightning adaptor. I use the long one as it seems to be more forgiving when it comes to bumps and have had no trouble with using it on my 12 or now the 14.
IPhone 5 trunk mount
View attachment 83675I used the 30 pin to lightning adapter (9 pin?). I also took my Otterbox belt clip, removed the "clip" part, mounted it with two screws on the swivel portion of the holder. First picture below is the holder in the normal position. Second one shows how it mounts to the trunk with two screws. Good luck!
