Starrider
It happened again today. This is the second time my 2015 F3s has gone into VSS Fault Limp Home Mode. Since I was at a point the ride where I couldn't turn back home at that time I decided to finish the ride. Each time the ride afforded some time to stop before completing the trip.
Each time after the stop I started out again in Limp Mode and then the warning would go away and everything went back to normal opertion.
The only thing that I can connect both instances was that I had just fueled up. My question is, would over filling with fuel trigger the code?
I'm open to any ideas.
