wvedec
I just got a 2016 Can-Am Spyder F3-T. I have a question about the instrument panel.
There are two analog dials - a speedometer on the left and a tachometer on the right.
With the Spyder turned off, the "mph" label on the left dial is not visible. Once I turn it on it becomes illuminated.
The "RPM X 1000" is visible when the Spyder is turned off. However, if I turn it on, this label does not become illuminated, even if I am riding in the dark at night.
Is this normal, or is there a light missing or burned out that is supposed to light up the "RPM X 1000" label on the tachometer?
Thanks for you help!!
