Instrument cluster
Unplugging is not a problem, just make sure you plug it back in without bending pins like I did. :gaah:
You can disconnect and connect without a problem...as Lamont and others said, just put it back on properly...it does have pins...
I actually opened the entire unit one time to clean out the 'snail trail' that it had when I bought it...cleaned the inside plastic with microfiber...there is no special coating inside to worry about and it looks great now...sealed it back up and it's been fine since...even through a serious thunderstorm!
