i would like to take a look behind the instrument cluster on my '19 F3T.
since my BRP connect does not recognize that there is a phone plugged into it, i am ruling out that the USB cable is or is not plugged into the cluster. i just want to remove it far enough to look behind where it should plug in. i have a couple questions:
-what are the chances that i will get this trim cover off without breaking it? it just pulls straight off, right?
if you have any suggestions on removing this piece correctly, i would appreciate them.
-assuming i get the trim off, how difficult will it be to loosen and tip the cluster out a bit to see behind?
-am i asking for trouble doing this?
-if anyone has removed the instrument cluster i would really like to hear about your experience.
i think i have the current software. my dash shows miles 'til empty
bluetooth sync works good
when i push the BRP Connect button, the dash says connect a phone. i have tried 3 different phones and 3 different cords, all apple brand. nothing works.
thank you for your help
ba
ba
