instrument cluster buttons quit working
Lamonster
SpyderLovers Founder
Look like both of mine quit working today. They may not have worked forever but today was the first time I tried them when I was setting the clock. I always use the M button on the bars so that's not a problem, the problem is it's stuck in the metric mode. :gaah: I don't know if this can be reset on the BUDS or I need a new cluster. :dontknow:
I am not sure , mine has always switched from metric to english . :dontknow:
Just don't use the GPS repair method on this :yikes: !! Hope you figure it shortly
good luck ,wish i could help.
You've got speedo/odo on the Garmin, so metric on the cluster (while annoying) isn't that big a deal, right? At least not enough to sweat before the trip.
Then again, it's electronic & electronics get hot. Maybe it's thirsty. :dontknow:
It's not a big deal unless I have starting issues or something like that, then I might do the GPS fix :D:yikes:
IWAY600 fix
:roflblack:
YouTube - iway 600 repair
:roflblack::roflblack::roflblack::roflblack: lamonster you kill me with your quick fix love the hamer:roflblack::roflblack::roflblack::2thumbs:great not going to bye one of them.and HAPPY FATHERSDAY MY Friend and to all of you out there too...........
I know you checked it out bye this time it's like a little magnet behind the rubber that makes contact on the cluster don't take the cluster out just the cover :gaah:
:bowdown::bowdown::bowdown::bowdown:
I pulled the rubber back and played with the magnet a bit and I'm back to miles again. :yes: Thanks a bunch Bro, I didn't know about the magnet but I do now. :2thumbs::doorag:
For once I was able to help you out.I don't think I can count how many times all of you helped me out :2thumbs:
I had the same problem with the one on my canam atv. They had a recall on it. The dealer just popped out the old rubber button and pushed in the new one.
I had the same problem after I removed the display "glass" to clean out the "snail tracks". Dealer fiddled with it and fixed it good as new at last service.
-Scotty
