Riker
I am looking at instructions and trying to match up the connection that I am supposed to disconnect and insert this kit, then run the wire to up behind the console.
I took the side panels off, and traced back the fender tip light to where the suspension meets the wheel/brake assemble. The connector I see is just inside there, several inches towards the body. However, it doesn't look like the wire lead will make it from there to behind the console.
Is this the right connector or is there another further in the guts
, and I just need to figure out a way to run that wire lead to the positive lead on the turn signal...?
Thanks for any advice :2thumbs:
