wyliec
pain trying to get the positive lead to connect to the battery.
It took about a 1/2 hr. before I got the two L terminals positioned so that I could connect the positive lead. I used the two L terminals for the positive side as someone had suggested. I mounted them together in the shape of a U and mounted it upside down. On the negative side, the leads connected directly to the battery; no L terminal left to use.
Because of the angle of the bend of the positive terminal, the U has to be opened a little (or closed) depending on how you look at it.
