moroccomole2004
So I finally got around to installing my NMN up & out mirror extensions. First off, excellent product. Well designed and matches the stock look perfectly. The directions are straight forward and make installation a breeze. I will say this after running the wires back through and then tightening all screws up I found where the stock mirror meets the new up & out to be kinda loose and to rattle. I was a bit concerned with this and thought that they would rattle in the wind. So later in looking in the box I found the packet of 4 washers and proceeded to install two per bracket. This seemed to correct the looseness, but there is a gap between the top and bottom mount. It is not a huge amount but is still there. My concern now is will this gap allow for water to collect if/when it rains?
In closing I so needed these up & outs as I had previously installed the NMN 4" risers are was looking more at my hands then in what was behind me. The up & outs sure fixed that problem. :spyder:
