Snoking1127
Well-known member
Yesterday and today have been tire days. Yesterday I installed to new rear tires on my Kawasaki KRX 1000 SxS and today I tackled the Spyder rear tire. I did the work in my carport in the RV Resort. I put the Spyder up on the blocks I use for oil changes and borrowed a HF aluminum roller jack from a friend to raise the rear.
Note in the picture how I kept it from moving on the blocks. I removed the muffler completely for easy access to the brake caliper and speed sensor which I removed during the installation. I also took the parking brake cable on the fixed bracket, and disconnected the ride height link.
Found a Mexican tire shop in Apache Junction that removed the old and mounted the new tire for 20 bucks. And they kept the Kenda also for the 20 bucks. Good deal in my mind.
The OEM Kenda had a lot of weights added. I did not balance the General and it is running nice and smooth.
I did not mess with the wheel/belt alignnment settings. I got the axle back in and then rolled the belt back on and that held the axle forward against the adjustment stops. I have a 250 ft lb torque wrench so tighting the axle to 166 was not an issue.
Tire is the 215/60-15 and now the speedo is off just 1 MPH vs the 2 MPH with the Kenda.
Oh, and I hate Can Am's yellow loc tight!!!!!
