IdahoMtnSpyder
I decided a few months ago that since I would changing my rear tire, and like to occasionally drive on gravel, that Doc's Air Ryde Rock Armour would be a good farkle to install. After I read all his instructions I said, "Oh crap!" The install is not a one hour simple process, mostly because you have to take the muffler and catalytic converter off to gain access to the air bag. And my dealer did not have the exhaust gasket and muffler clamp in stock. After stalling for a week I decided to see if in fact I could do the install without removing the muffler and converter. Since I had the rear tire off I had a lot of access to the shock and air bag area.
Well, I did it! :yes:
First, you do need to follow Doc's instructions regarding removing tupperware I raised the bike on some planks and my ATV jack. Here's a pic. That afforded me a fair amount of working space.
I took the valve out of the air bag Schrader valve so that it would easier to move air in and out of the air bag. When you get to Doc's instructions for removing the muffler and catalytic converter, you just skip over them. Next few steps are to remove the the lower shock absorber bolt and the bolt holding the air bag. I put the axle into the swing arm so I could jack it up and down as needed, both to the get the shock bolt out and to give space above the converter to remove the air bag bolt. I cut a V notch in the end of a 8" long 4 x 4 to fit between the jack and the axle.
Here's a pic of the air bag as seen from the left side.
Here's the tire inflator setup I used to move air in and out of the bag.
Here you see the underside of the swing arm where the air bag bolt goes through. By jacking up the swing arm as far as possible it's quite easy to remove the bolt. Doc's replacement bolt is longer but it fits in the space very nicely.
Continued in next post.
