Install of permanent heat controllers.
I've done this install but did not document it. There are so many variables but the most important is to decide where to put it. It needs to be easily accessible so as not to distract you too much from your primary mission which is to safely pilot your Spyder.
It also has to be a location where you have room to work and run the wires.
Here are a few videos that might help.
[h=3]Warm & Safe: How to install a Heat Troller on a motorcycle - YouTube[/h]
[h=3]FirstGear: How to install the Heat-Troller onto your motorcycle ...[/h]
[h=3]Firstgear Mounted Heat-Troller Motorcycle Installation at RevZilla ...[/h]
You can put a small battery in Sid box just for heated things, but the 650 w just not good to puts all the elec on bike and heated clothing. That way I but battery in side box for them only. That way main will not Die on you.?? P S carry jumps with you for bike when it does go down?
I use the remote controller that uses battery's to control my heated clothing run off of my bike battery. I have a lot of accessories and still have power to run my heated jacket, gloves and socks. I have it stuck under the dash of my RT using Velcro.
