INFO LAMPS SPYDER RS
gozzillaman
NEW FORUM OF EXCUSES ARE ALIVE IN ITALY AND OWN A FANTASTIC RS SPYDER SE5 2009
I WOULD LIKE TO KNOW WHAT KIND OF LAMPS low and high beam RIDING MY SPYDER, SINCE THE SERVICE MANUAL NOT HAVE FOUND NOTHING
Sorry if it is NOT THE RIGHT SECTION
GREETINGS TO ALL FROM ITALY ARE STRONG
:welcome:The manual recommends running on high beams during the day.
Your low/high beam lamps and light assemblies in Europe are different than our here in the US. You should get some input from another European rider or a friendly dealer who will venture outside the BRP parts fiche. :welcome:
Low beam= daytime running lights= fog lights in US: permanent.
High beam= high beam US: switch on left handlebar.
INFO LAMP
THANK YOU FRIENDS FOR YOUR MAGNIFICENT WELCOME TO FORUM
MAYBE NOT SO I WAS CLEAR TO U.S. THAT THE MODEL OF LIGHT is different from Europe, I WOULD LIKE TO KNOW WHY I HAVE INTENTION TO ASSEMBLE THE HID KIT
:welcome: Not sure of your question ,but I found that the HIDs I installed on my 2009 RS made a world of difference .
Great to have another International Spyder Lover on the forum.
Be sure to get a well made HID lighting kit or you will have MAJOR issues with your Spyder. Poorly made HID kits will interfear with your ECM (Computer). I put a cheap kit on my RS and it got to where it would not start. Pulled the headlight relay and my Spyder started and ran fine.
I put a 4300k Xtreme Motorcyle Xenon kit from KB Car Stuff (a Spyderlovers Sponsor) on my Spyder and I higly recommend it. The USA RS Spyder takes the H7 bulb set, but I am not sure what your European Spyder takes. These guys have all the bulb sets so you should be able to find a kit that will work for you.
You can see them here
http://www.kbcarstuff.com/Motorcycle-Xenon-HID-Conversion-Kits-s/34.htm
In Europe, they use a separate low beam down on the Spyder body. This location has air intakes in the US, unless foglights are fitted. In Europe, the high beams are located on the console, where the US headlights are located. The European lights switch from location to location for the high/low beams. The US lights just use the upper light assemblies, and cover the upper portion of the lens with a shutter for low beams.
European High Beam Assembly ----- P/N 710001601
European High Beam Lamp ----- P/N 415129249
European Low Beam Assembly ----- P/N 710001602
European Low Beam Lamp ----- P/N 415129249
US High Beam Assembly ----- P/N 710001039
US High Beam Lamp ----- P/N 219400069
US Low Beam Assembly ----- P/N 219400084
US Low Beam Lamp ----- P/N 219800149
As you can see from the part numbers, everything is different. There is probably an HID retrofit available for your European machine, but you will have to pull a lamp and get the designation or match it up, unless you can get some the right lamp ID from another European rider. If you use a plug-n-play HID kit, you may have issues with the connectors, as the European machines use different wires in the same harness and switch from high to low differently. Also check your local regulations, as some jurisdictions may not permit the use of the brighter HIDs on low beams.
