In need of new tire
As far as I know and have experienced, Advantage Powersports and Renos both will only replace Spyder tires with OEM Kenda. I have had work done at both dealer service departments and find them friendly and reliable. I don't know of any independent shops that will work on Spyders in the KC area but I am sure there may be some. Good luck.
THE rest of the story.....
Thanks. That is what I was afraid of. New Kenda is still better than worn Kenda.
So where did you end up going and how much did it run you?? New owner but the handwriting is on the wall as far as the rear tire is concerned!
If you feel like a drive...
YC Powersports in Columbia, MO is more into Spyders than they used to be...I just purchased a few things from them. They maybe able to help.
Just had mine tires balanced at Big O tire and they stated that whatever tire you wanted to install they could get and install.
Might talk to your local BigO tire store or whatever its called in your area and see.
